Small geo selection RFE
   2254   0   0
When reselecting geometry for operation (tilde key), the Geometry Selector menu should not pop up when you Shift+Right Click. Also when you complete the selection it will move the position of the current SOP as if you had hit ‘l’. Very annoying when you are repeatedly branching from the same SOP and Houdini goofs with your layout. Hope that made some sense…
Cheers. :]
