Hi all
how do you get a roughness parameter properly working in the bsdf specular() function:
the followong code is not working as expected: (result is just diffuse shaded no spec high light at all), compiles fine.
float rough =.01;
vector nml,V;
V = -normalize(I);
nml = frontface(normalize(N), I);
F = (Cd * diff) * diffuse();
bsdf carp_bsdf = specular(nml,V,rough)*basecolor;
F += refl * (clampcolor / albedo(carp_bsdf)) * carp_bsdf;
the following is looking good, but I can`t adjust roughness
vector nml,V;
V = -normalize(I);
bsdf carp_bsdf = specular(nml)*basecolor;
I might just miss something obvious here.
bsdf specular() question
4281 3 0- alexlstephan
- 13 posts
- Mario Marengo
- 941 posts
The function specular(nml,v,rough) returns a vector, not a bsdf – it is the old (non-pbr) function that produced VEX's custom specular model (with an implicit illuminance loop inside it). The PBR function that emulates it is matchvex_specular(nml,rough) which returns a bsdf as you expect.
The bsdf version of plain specular(vector dir) in the second example of your code, is intended to be used for *mirror* reflections (and dir is usually the direction of perfect “specular” reflection, not the surface normal), which explains why you couldn't adjust its roughness.
HTH.
HTH.
- alexlstephan
- 13 posts
thanks, that helps. however, I am not sure what direction of perfect “specular” reflection means" so I shouldnt use frontface(normalize(N), I) as an input?
- Mario Marengo
- 941 posts
AlexStephan
No, it would normally be:
vector R = normalize(reflect(I,N));
bsdf bsdf_refl = specular(R);
Though, of course, it could be anything you want, but that would be the mirror reflection, which is the typical usage.
P.S: I can't remember if reflect() needs the arguments normalized, but I don't think so… you should check anyway.
