edge sliding
4322 3 1- koyoteblack
- 31 posts
can you edge slide in houdini?…invaluable to the box modelling process…
This is my blog on using Houdini http://urubolous.tumblr.com/ [urubolous.tumblr.com]
- MWainwright
- 119 posts
not that i`m aware of.. which is a real shame.. sometimes i template the node previous to my edit and use that.. but of course then you cant slide your currently edited points..
annoying.
it might be possible to build a crude asset.. youd need to update a snapshot of the mesh after every edit then re-use it as a template and snap to edges..
any ideas from the forum?
annoying.
- Pagefan
- 519 posts
- Simon
- 2199 posts
I wrote a point slide tool but really it needs integrating into the edit sop. I would hassle Sesi to do it properly.
http://www.fourthwall.ndo.co.uk/HT_HDK_PointSlide.html [fourthwall.ndo.co.uk]
