There seems to be some rounding errors going on with H9's lookup CHOP at high sample rates. Here's an example scene, any ideas?
I locked the node in the version 9 scene for a subtractive comparison. Enable the audio flag and listen to the result in each you'll see what I mean.
In H8 it works fine. The file is a bit large for an attachment so here's a link
http://www.andrew-lowell-productions.com/andrew-lowell-productions/lookupbug/lookup_problem.zip [andrew-lowell-productions.com]
I've seen some strange stuff going on with the hold CHOP and sample-accuracy as well in H9, could it be the same bug?
lookup CHOP problem or bug at high sample rates
1862 0 1- andrewlowell
- 539 posts
