Python Sop Subframe Evaluation
   2596   0   1
Sorry for the crosspost with the list:
I bumped into an interesting problem with my third python SOP:
Basically I generate point positions for each integer frame, and from this, I (for now) linearly blend subframe data, which is fine.
When I eyeball my result in the viewport for non-integer frames, it all looks just fine.
Now, let's try motionblur as that's always the killer of this kind of things, directly rendering the SOP: nothing.
However, if I archive the geometry output of my SOP at $F and $F+shutter, and render that
(either as a DRA or simply with a fileSOP with no time*SOPs attached), I get the proper blur.
I tried this with all the three shutter evaluation modes, and (obviously after changing the archives) it all worked.
What am I missing? Or is this a limitation of PythonSOPs/Soho? A possible bug?
Thanks,
Andras
