Weird behaviour with glue objects and forces
   2905   0   1
I wondered if forces or particles alone could break glue, and what I've found is, sometimes it will and sometimes not.
Please look into attached file (originally found on odforce) : in the dopnet 2, if the gravity is enabled, the fan acts and blow the cube, but if it's bypassed, nothing happens.
Did some more test, with a rbd pin constraint (added in the file), even with gravity and fan enabled nothing break.
Thanks a lot if you can help me explain what's going on.
7_explosion_h9_weird.hipnc (204.2 KB)
