Save Desktop Across Dual Monitors?
   2251   0   0
I have 21“ and 17” monitors setup in Dualview display mode.
I've saved the Build desktop with the Network View pane on the 17" monitor and this works nicely.
When I restart Houdini, the Netwtork View is absent from the second monitor. However if I switch to and from the Build desktop within the same session, the correct layout is restored.
Cinema 4D is able to save desktops across both monitors in Dualview mode between sessions. Is there a setting in Houdini which will allow me to do this?
