Maya Python to Houdini Python
   Views 7485   Replies 1   Subscribers 0
I'm trying to port some maya python rigging scripts to houdini python scripts to post it on my rigging blog as examples, shameless plug follows: Please visit my blog at
http://vanillarigging.blogspot.com [vanillarigging.blogspot.com]
If all goes well maybe start some sort of transition guide or repository about python in maya and houdini.
I know that sort of thing will help the houdini community.
Anyway I'm kind of lost at the first attempt to get a selection out of houdini.
Here is maya code
“maya.cmds.ls(selection=True)”
which will return a list of all the objects selected, transforms, shaders, custom nodes you name it.
I was advised that I could do something like this in houdini
loop trough all children of /obj and test for selection with hou.Node.isSelected().
This works but I think this method has some big issues. First is the loop, if I have thousands of objects it might take a while . The bigger issue to me id the fact that this seems to go backwards, instead of saying give me the selection it says give me all the objects then take the selected out.
Could someone (Luke, maybe) please point me to a better, simpler way of getting my selection from houdini, wink wink, see the simplicity of mayas
cheers
calin
ps. I'm sure tons of question will follow because here is the script I'm trying to port:
import maya.cmds as mc
# Build the UI
def startUI():
print ‘starting the UI’
# end of UI
def createJoints(nrJoints, boneLength):
# create a number of joints, ‘nrJoints’ along the Y axis
# the joints will be spread apart by the ‘boneLength’ value
print ‘Create Joints’
jointsList =
# create the root joint then orient it to point in +Y
jointName = mc.joint(position0,0,0), name='spineJoint1', orientation-90,0,90))
jointsList.append(jointName)
for i in range(2, nrJoints):
jointName = mc.joint(positionboneLength,0,0), relative=True, name='spineJoint' + str(i))
return jointsList
def addBoneLengthToJoints(jointsList):
# add an ‘originalLength’ attribute to every joint that follows after root
# that stores the original length. Since the translate X is taken as original
# length the joints must be oriented along X for custon skeletons
print ‘Add original bone length attribute to joints’
selection = mc.ls(selection=True)
# take the root joint out of the joint list because there is no bone length
# on the root joint
stretchJointsList = jointsList
for i in stretchJointsList:
mc.select(i, replace=True)
tempXvalue = mc.getAttr(i + ‘.translateX’)
mc.addAttr(longName='originalLength', attributeType='double', defaultValue=tempXvalue)
mc.setAttr(i + ‘.originalLength’, lock=True)
return stretchJointsList
def createSpineHierarchy():
# create a spine hierarchy where the joints are unde the skeleton group,
# the controls under controls group and everything else is under the helpers group
print ‘Create spine hierarchy’
spineRig = mc.createNode('transform', name='spineRig')
spineSkeleton = mc.createNode('transform', name='spineSkeleton', parent=spineRig)
spineControls = mc.createNode('transform', name='spineControls', parent=spineRig)
spineHelpers = mc.createNode('transform', name='spineHelpers', parent=spineRig)
mc.setAttr('spineSkeleton.template', 1)
spineHierarchyList =
return spineHierarchyList
def buildStretchySpine(spineJointsList, stretchJointsList):
# create the stretchy spine setup based on the provided diagram
print ‘Build stretchy spine’
# adding spline IK solver to the bones
print ‘Add IK solver’
mc.ikHandle(name='spineIkHandle', startJoint=spineJointsList, endEffector=spineJointsList, solver='ikSplineSolver', numSpans=2)
spineSolverCurveShape = mc.ikHandle('spineIkHandle', query=True, curve=True)
spineSolverCurve = mc.listRelatives(spineSolverCurveShape, parent=True)
mc.setAttr(spineSolverCurve + ‘.template’, 1)
spineCurve = ‘spineCurve’
mc.rename(spineSolverCurve, spineCurve)
mc.parent(spineCurve, ‘spineHelpers’)
# create the curveInfo node that will compute the arclen of the spine
print “Add cruveInfo node that computes the spine's length”
spineCurveInfoNode = mc.arclen(spineCurve, constructionHistory=True)
spineLengthNode = ‘spineComputeCurveLength’
mc.rename(spineCurveInfoNode, spineLengthNode)
# store the original curve length in the ‘originalLength’ attribute
print “Add spine curve original length attribute”
spineCurveOrigLength = mc.getAttr(spineLengthNode + ‘.arcLength’)
mc.select(spineCurve, replace=True)
mc.addAttr(longName='originalLength', attributeType='double', defaultValue=spineCurveOrigLength)
mc.setAttr(spineCurve + ‘.originalLength’, lock=True)
mc.parent('spineIkHandle', ‘spineHelpers’)
mc.setAttr('spineIkHandle.visibility', 0)
# create a locator which will be a control for spine options, stretchiness
# we default this value to .2 which means that the spine will stretch and
# compress with .2 of the difference between the original length and the
# current length
print ‘Create a control for the spine options’
spineOptions = mc.createNode('transform', name='spineOptionsCtrl', parent='spineControls')
mc.createNode('locator', name='spineOptionsCtrlShape', parent=spineOptions)
mc.setAttr(spineOptions + ‘.translateX’, 4)
mc.parentConstraint('spineJoint1', spineOptions, maintainOffset=True)
print ‘Add spine options attributes’
mc.select(spineOptions, replace=True)
mc.addAttr(longName='spineStretchiness', attributeType='double', minValue=0, maxValue=1, defaultValue=0.2, keyable=True)
# create the stretchiness network which mainly consists of adding shading nodes
# and connect attributes
print ‘Add stretchiness network’
# create a plusMinusAverage node. this node will take the current length
# and subtract the original length to find out with how much the curve changed
spineSubtractOriginalCurveLengthNode = mc.shadingNode('plusMinusAverage', asUtility=True, name='spineSubtractOriginalCurveLength')
mc.connectAttr(spineLengthNode + ‘.arcLength’, spineSubtractOriginalCurveLengthNode + '.input1D', force=True)
mc.connectAttr(spineCurve + ‘.originalLength’, spineSubtractOriginalCurveLengthNode + '.input1D', force=True)
mc.setAttr(spineSubtractOriginalCurveLengthNode + ‘.operation’, 2)
# create a multiplyDivide node that multiplies the result from the subtract node with
# the spine stretchiness to find out what's the length we care about
spineMultiplyStretchinessNode = mc.shadingNode('multiplyDivide', asUtility=True, name='spineMultiplyStretchiness')
mc.connectAttr(spineSubtractOriginalCurveLengthNode + ‘.output1D’, spineMultiplyStretchinessNode + ‘.input1X’, force=True)
mc.connectAttr(spineOptions + ‘.spineStretchiness’, spineMultiplyStretchinessNode + ‘.input2X’, force=True)
# create a plusMinusAverage node and we add back the original curve to find out the
# total length of the curve we have to stretch the bones
spineAddOriginalCurveLengthNode = mc.shadingNode('plusMinusAverage', asUtility=True, name='spineAddOriginalCurveLength')
mc.connectAttr(spineMultiplyStretchinessNode + ‘.outputX’, spineAddOriginalCurveLengthNode + '.input1D', force=True)
mc.connectAttr(spineCurve + ‘.originalLength’, spineAddOriginalCurveLengthNode + '.input1D', force=True)
# create a multiplyDivide node and divide the total length we care about with the original
# length to find out the ratio.
spineDivideByOriginalCurveLengthNode = mc.shadingNode('multiplyDivide', asUtility=True, name='spineDivideByOriginalCurveLength')
mc.connectAttr(spineAddOriginalCurveLengthNode + ‘.output1D’, spineDivideByOriginalCurveLengthNode + ‘.input1X’, force=True)
mc.connectAttr(spineCurve + ‘.originalLength’, spineDivideByOriginalCurveLengthNode + ‘.input2X’, force=True)
mc.setAttr(spineDivideByOriginalCurveLengthNode + ‘.operation’, 2)
# once we know the ration we have to create a multiplyDivide node for each joint
# and multyply the original bone length with the computed ratio
print “Change the bone Tx value to accomodate stretchiness”
spineMultiplyByOriginalBoneLengthNode = mc.shadingNode('multiplyDivide', asUtility=True, name='spine' + i + ‘MultiplyOriginalLength’)
mc.connectAttr(spineDivideByOriginalCurveLengthNode + ‘.outputX’, spineMultiplyByOriginalBoneLengthNode + ‘.input1X’, force=True)
mc.connectAttr(i + ‘.originalLength’, spineMultiplyByOriginalBoneLengthNode + ‘.input2X’, force=True)
mc.connectAttr(spineMultiplyByOriginalBoneLengthNode + ‘.outputX’, i + ‘.translateX’, force=True)
def createClusters():
print ‘Create clusters’
for i in range(0,5):
cv = 'spineCurve.cv' %i
cluster = mc.cluster(cv, name='spineCurveCluster' + str(i))
mc.parent(cluster, ‘spineHelpers’)
def main(createJointsOption, nrJoints, boneLength):
if createJointsOption==1:
spineJointsList = createJoints(nrJoints, 2)
spineHierarchyList = createSpineHierarchy()
mc.parent(spineJointsList, spineHierarchyList)
stretchJointsList = addBoneLengthToJoints(spineJointsList)
createClusters()
main(1, 20, 2)
Great topic Calin!
I have not a lot of time at the moment but just to feed the thread this is a litte bit of python code.
Create nulls oriented at the tip of bones:
On the shelf:
import hou
import toolutils
import pythonrc
reload(pythonrc)
cwd = toolutils.sceneViewer().pwd()
selected =
pythonrc.createNullsTipsOriented( selected )
the functions needed in pythonrc.py:
def childTipRoot ( child, tipRoot = 1 ):
child.movePreTransformIntoParmTransform()
rotation = hou.Matrix4.extractRotates( child.parmTransform() )
rotationMatrix = hou.hmath.buildRotate( rotation )
parent = child.inputs()
boneLength = parent.parm('length').eval()
print boneLength
parentWmatrix = parent.worldTransform()
child.setWorldTransform( parentWmatrix )
child.moveParmTransformIntoPreTransform()
if tipRoot == 0:
print “child is moved to the root”
child.setParmTransform( rotationMatrix )
else:
print “child is moved to the tip”
child.parm('tz').set( -1 * boneLength )
child.setParmTransform( child.parmTransform().__mul__( rotationMatrix ) )
def createNullsTipsOriented( nodes ):
nulls =
for node in nodes:
node.setSelected( 0 )
null = hou.node('/obj').createNode('null')
null.setWorldTransform( node.worldTransform() )
null.setFirstInput( node )
null.setSelected( 1 )
childTipRoot ( null, tipRoot = 1 )
null.setInput( 0, None )
null.moveParmTransformIntoPreTransform()
