Parm button gets stuck after been clicked
   2169   0   0
I have a problem when I click on my button in a SOP function, the button get “pressed down” and it stays in that position for couple of minutes, unless I click on another SOP function and back to my SOP, then its back to normal.
I can continue to click on the button, when its still in “pressed down” mode, and it will run its functions when I do.
I have checked other peoples SOP code, but I cant find any obvious code snippet that I need to run to make the button pop back to normal again.
Is it some function you need to run in order to set a PARM button back to default position?
Im using Houdini 8.2
You cant recycle wasted time
