How to create Group for part of Particle Fluid Object?
   Views 2959   Replies 3   Subscribers 1
I want to create two different group for 2 parts of Particle Fluid Object. This groups use same Fluid Solver, Gravity force but will have different color for example. Somebody can help to do this?
best regards
ruslan_3d
This depends on what you're specifically attempting to do… Are you trying to have two liquids mix with each other? Are you trying to have your fluid generate white water?
Stephen Tucker
VFXTD
I want to have fluid's parts with two different material on its. But this parts need to stave in ONE solver . . .
best regards
ruslan_3d
Hi ruslan_3d,
Did u find an answer for this… Im in the same situation, I want to create two different group for 2 parts of Particle Fluid Object…
thx in advance
Shanmug
