hconfig command not found
   3401   1   0
Hi!
when I type hconfig in terminal, it says that there is no such command
same thing happens in a textport
is there something wrong with my path variables, so the program can't find hconfig file?
I'm using Suse linux
thanks
Best Regards,
Sasha Reyev
スタッフ
you may need to explicitly source the houdini_setup file in your terminal. That file will set up the PATH variable. The hconfig is located in the bin subdirectory withn the directory where you installed houdini. The $HB points to that directory ($HB is also defined by houdini_setup).
See this FAQ for more info (the “accessing Houdini” part for Linux):
http://www.sidefx.com/index.php?option=com_content&task=view&id=1207&Itemid=273#install [sidefx.com]
