BUG: Houdini 9.5.223 on OS X
   4632   5   1
The application is freezing if you try to choose the animate desktop.
Or
The application is freezing if you try to add the motion view through new pane tab
I can confirm the bug, and its still present in 9.5.230
qral
Not sure if I am the only one but do you guys have a significant lag when panning in network panes (SOPs) as well? 9.5.230
… network panning is fine here!
qral
I have something similar on 230. A message pops up that says it caught an internal error and it was logged to the shell. If I continue entire panes disappear. This is what was dumped to the shell:
2008-09-20 16:59:37.640 houdini invalid drawable
2008-09-20 16:59:37.643 houdini invalid drawable
2008-09-20 16:59:37.644 houdini *** Assertion failure in -, RE_OSXCustomView.mm:121
Downloading 234 now and will try again.
Still messed up. Tried some of the included desktops and some of those still take it down. I did notice an extra line that was logged to the shell after the assertion fail:
2008-09-20 17:08:48.339 houdini Unlocking Focus on wrong view (<NSThemeFrame: 0x8003911e0>), expected <RE_OSXCustomView: 0x8000f75e0>
-Victor
