HDK
   2528   0   0
Hi
I am using Houdini Apprentice 9.5 and was trying to do a bit of HDK programming. At first before coding my own SOP, I tried to compile one of the examples in the toolkit directory (StarSOP). It compiles fine and the corresponding dll is generated and Houdini Apprentice loads the dll as well ( I get the SOP in the tab menu in Geometry) but the moment I select it and press Enter, the application crashes (Segmentation fault). Has anyone tried this before? I dont have any idea why this happens. Is it because I am using the Apprentice edition?
I compiled the code using hcustom and not VC++.
thanks
