switch shop and material overrides
   2226   0   1
Is it possible to override switch shop input parameter using material SOP?
I play with it and wanted to randomly distribute some shops on prims.
I have material node with switch and 3 simple shops inside.
Input param is referenced right in material node.
I easily use this technique with VOP switch, and it just works.
thanks
