Group Centroid
   4082   2   1
I am doing a video tutorial and they are asking me to move deselect the group centroid option box?
They are using version 5.xx and i am using 6. I would like to know where the
PivotAboutGroup Centroid option actually is to toggle
Ilan
Yeah, I came up against that too. I just guessed that now the option is just to set the pivot point in the parameters page … and the missing bit is, you can set the values to $CEX, $CEY and $CEZ which are the values of the input geometry centroid.
Just be careful, I've had some weirdness happen when using transforms that if you make a transform and then decide to use the centroid and change the pivot, it doesn't seem to like it. I'm not sure about that … will have to do some testing.
Cheers.
Jonathan.
Hi there,
The “Pivot about Group Centroid” toggle has been removed from 6.0 and the default behaviour for “Pivot about Group Centroid” is always off.
Cheers!
steven
