Hi Community,
I've got the lastest build Houdini 9.5.350 and I've got this error. I happens when I hit the tab key in the output to see the tool menu. The image is attached below.
If you can't see the words. the error says:
Fatal error: data saved to CDOCUME~1/ADMINI~1/LOCALS~1/Temp/Administrator.4576.hip
Then there's the ok button.
Below is a Houdini Console window that says:
4576: Fatl error: Segementation Fault
saving application data to CDOCUME~1/ADMINI~1/LOCALS~1/Temp/Administrator.4576.hip
Ast this point I can add anythig to the output tab until the issue is resolved, can anyone help me?
Houdini Error
10917 7 2- ebonixs
- 16 posts
- edward
- 7903 posts
- edward
- 7903 posts
- Blackstone
- 16 posts
- IndyZoneCo
- 77 posts
Are you using a dual monitor setup?
If you are, you need to upgrade to the latest Nvidia driver and use Houdini builds that are no older than 9.5.357.
Check out the Houdini Journal (9.5.357) for details.
http://www.sidefx.com/index.php?option=com_journal&Itemid=213&page=index&journal=default [sidefx.com]
- theAdmira1
- 7 posts
- ebonixs
- 16 posts
- edward
- 7903 posts
