OTL question
   2177   0   0
Hi all,
I have 2 problems:
1/
I'm trying to create an otl with 1 entry wich drive a deformer inside the otl.
I also have a custom parameter wich activate or not the deformation (with a switch inside)
But… once it's done, my otl doesn't work except when I connect something in the input (even when my deformation is off)
is there a solution to have some optional entries ???
I guess I'm doing something wrong.
2/
I also have a point sop creating a world noise deformation (using $TX, $TY, and $TZ value) but of course when I use the transform attribute at the obj level my noise is not used because it's using the “local” space inside the otl, and not the world transformation.
I have created some custom transform nodes which are looking at a faked transform value at the up level.
So… as it seems to me a strange way to resolve that problem, I'm wondering if is there another way to do that ?
I hope my explanation is clear enough
all your advice are welcome !!
thank you
