Houdini Console Error Message
   2851   0   1
Hi.
I got this error message yesterday while starting Houdini.
Warning: OpenGL shader extensions not available.
This is a limitation of your video card
or driver, and will prevent Houdini from
using GLSL shaders.
Set the HOUDINI_OGL_ENABLE_SHADERS
environment variable to zero to avoid
attempts to use this extension.
I first tried to change the version of my graphic card to latest one,
but it didn't work :? So I wanted to try second one.
I searched the Internet and got some useful infomation.
However I don't know how I operate this. This is it.
go to the System Properties and go to the Advanced tab and click on Environment Variables. Click to create a new variable and set the variable name to HOUDINI_OGL_ENABLE_SHADERS and set the variable value to 0.
If you can do this, would you plz give a detail explanation to me? :cry:
