Simulation to match my Frame 1 animation?
   2430   1   1
Hi all,
I have a tracked camera in my scene and it starts from frame 1.
However, if i want my simulation to start running half way through and use a portion of my simulation (at probably frame 50) to match my frame 1 camera, how do i do that?
Hi diskhub,
You write out the simulation, read it back in with a File SOP, append a Time Shift SOP and use $F + 49 so on Frame 1, Frame 50 of the simulation is read from disk.
You can also set up preroll but since you already have a simulation you like, I will just do the above method.
Hope this helps!
Cheers!
steven
