ground explosion problem
   2024   0   1
here is a hip file, please download it first.
I make some particles and replace them to debris(I used a ball here.), then use these balls to emit other particles which I wanna replace to sprite.
it should be exploded and fall down on floor, then stop emit sprites.
my problem is : what attribute should i make, it can call another node's attribute for kill the useless particles(which replaced by sprite.)?
I tried use add an attribute node and give it $TY value, and set it : if $TY is going to be 0, then const. birth rate =0. If not, the const. rate is 1000.). But it didnt work.
groundExp_02.hip (75.8 KB)
https://vimeo.com/jacyslin [vimeo.com]
