I'm unable to install hqueue and receive the following error.
“Table ‘hqserver.client_errors’ doesn't exist” - I checked, it does not exist in the db.
Any ideas?
…successfully created the ‘hqserver’ database.
Starting HQueue…
File “./bin/paster”, line 8, in <module>
load_entry_point('PasteScript==1.7.3', ‘console_scripts’, ‘paster’)()
File “/opt/hqueue/lib/python2.5/site-packages/PasteScript-1.7.3-py2.5.egg/paste/script/command.py”, line 84, in run
invoke(command, command_name, options, args)
File “/opt/hqueue/lib/python2.5/site-packages/PasteScript-1.7.3-py2.5.egg/paste/script/command.py”, line 123, in invoke
exit_code = runner.run(args)
File “/opt/hqueue/lib/python2.5/site-packages/PasteScript-1.7.3-py2.5.egg/paste/script/appinstall.py”, line 68, in run
return super(AbstractInstallCommand, self).run(new_args)
File “/opt/hqueue/lib/python2.5/site-packages/PasteScript-1.7.3-py2.5.egg/paste/script/command.py”, line 218, in run
result = self.command()
File “/opt/hqueue/lib/python2.5/site-packages/PasteScript-1.7.3-py2.5.egg/paste/script/appinstall.py”, line 456, in command
self, config_file, section, self.sysconfig_install_vars(installer))
File “/opt/hqueue/lib/python2.5/site-packages/PasteScript-1.7.3-py2.5.egg/paste/script/appinstall.py”, line 600, in setup_config
mod.setup_config(command, filename, section, vars)
File “<stdin>”, line 24, in setup_config
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/schema.py”, line 1792, in drop_all
bind.drop(self, checkfirst=checkfirst, tables=tables)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/engine/base.py”, line 1134, in drop
self._run_visitor(self.dialect.schemadropper, entity, connection=connection, **kwargs)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/engine/base.py”, line 1158, in _run_visitor
visitorcallable(self.dialect, conn, **kwargs).traverse(element)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/sql/visitors.py”, line 89, in traverse
return traverse(obj, self.__traverse_options__, self._visitor_dict)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/sql/visitors.py”, line 200, in traverse
return traverse_using(iterate(obj, opts), obj, visitors)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/sql/visitors.py”, line 194, in traverse_using
meth(target)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/sql/compiler.py”, line 962, in visit_metadata
collection =
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/sql/compiler.py”, line 973, in _can_drop
return not self.checkfirst or self.dialect.has_table(self.connection, table.name, schema=table.schema)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/databases/mysql.py”, line 1607, in has_table
rs = connection.execute(st)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/engine/base.py”, line 824, in execute
return Connection.executors(self, object, multiparams, params)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/engine/base.py”, line 888, in _execute_text
return self.__execute_context(context)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/engine/base.py”, line 896, in __execute_context
self._cursor_execute(context.cursor, context.statement, context.parameters, context=context)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/engine/base.py”, line 950, in _cursor_execute
self._handle_dbapi_exception(e, statement, parameters, cursor, context)
File “/opt/hqueue/lib/python2.5/site-packages/SQLAlchemy-0.5.1-py2.5.egg/sqlalchemy/engine/base.py”, line 931, in _handle_dbapi_exception
raise exc.DBAPIError.instance(statement, parameters, e, connection_invalidated=is_disconnect)
sqlalchemy.exc.ProgrammingError: (ProgrammingError) (1146, “Table ‘hqserver.client_errors’ doesn't exist”) ‘DESCRIBE `client_errors`’ ()
ERROR: Could not setup HQueue application.
Exiting installer…
thanks!
