Min And Max Values From A Point Attribute
   Views 15955   Replies 11   Subscribers 2
Hi!!
In VOP SOP how can i find the Min And Max values of a point attribute from all the existent points in the input geometry?
I don't think you can without looping through all the points. Its probably better to just use the AttribPromote SOP to do it for you, then look up the results.
What Wolfwood said. Because of the way VOPs works you cannot get that information from a feature inside of your VOP network. The Attribute Promote is the best way to do it.
Attached is an example file that uses two of them to get the min/max as detail attributes and passes them to the Vop Sop using Parameter vops.
min_max_pt_attrib_in_vops.hip (56.0 KB)
Thank you very very much.
But if i want to do in the VOP SOP; how is the workflow for looping all the points?
Thanks you!!
If you must then you'd use a For Loop VOP and the Import VOP.
I've always maintained that such often-used values (min, max, avg) need to be stored at creation – can you imagine how much easier it'll be normalize attribute values for whatever devious purpose you might want?!
G
alejandro
you probably do not want to do that
because it will be run for every point of your geo
so imagine you have 1000 points
when 1st point is processed it will invoke for loop which will import point 1000 times and calculate min, max, avg or whatever
and use that value for something
so far so good
but 2nd point will do the same thing, it has to loop through 1000 points to compute the value for itself because it cannot access min, max, avg computed by 1st point
so if 1000 points compute this value 1000 times then your code will be way slower than if you bring allready precomputed value from outside this VOP
this is how i understand VOPs, if it is wrong or not completely accurate please correct me someone
Once again, not to dance around the issue, but to offer a workflow alternative:
I believe it might have been Jesta that turned me onto this particular trick many moon ago, but it works quite well.
in a branch off your network stuff your attribute into $TY. This will allow you to use $YMAX and $YMIN to look up the relevant bits of information.
Best,
G
keyframe
Best,
G
I understood your concern.
branch off your network stuff your attribute into $TY. This will allow you to use $YMAX and $YMIN. Stuck with the same kind of problem and kind of new to Houdini. can you explain me the process exactly?
@himkhu….your responding to the last post from 2009.
Perhaps you could post your hip with the issue so that someone might be able to help you.
BabaJ
so I have 1000 points in a 3d space, and i calculated the distance of each of them from the camera and stored in f@dist point attribute.
right now i am using attibpromote node 4 times ( first to promote min dist to detail second for max dist and then rest of the two back to point attribute ).
I am wondering what Mr keyframe implying is if you can store it in $TY and use query $YMAX and $YMIN would be the best alternative way of doing the same thing. but i am not sure what exactly has to be layed down in houdini to achieve this.
so if someone can explain the step by step process would be a great help.
thanks for the concern by the way didn't notice this post was from 2009. just stumbled upon it from google.
As for myself I don't know what he is referring too other than he is using an hscript approach using $TY and $TMAX $TMIN.
Which although is an old post is still perfectly valid way of doing something - its just I'm not versed well in Hscript and can't help you.
I do know a couple ways of doing it in a vex wrangle - but that's not what your interested in knowing , and I don't know if it would be more efficient than using the attribute nodes the way you have done.
Hopefully at some point someone can chime in for you on the Hscript at some point.
To help someone help you, post your hip so its less work for them and more likely to respond. There can many different ways of doing the same thing. So if you give people your approach (your current step by step attempt), they might be able to respond with a simple comment or modification of your code. Otherwise, they just might not have the time to lay out an example for you.
