error propagation in output/ROP subnetwork nodes
   1484   0   0
I'm using Houdini 9.5.379, and I'm creating an Output Subnetwork, it works great and everything that's inside the subnetwork gets rendered when I hit the render button.
The problem is that if one of the renders inside the subnetwork fails, I want to know about it. By default, you have no way of knowing whether anything failed or succeeded under the hood.
Is there a setting on the Subnetwork node to make it so that any errors on the internal nodes trickle up so that they are visible in the Subnetwork node?
This is a really important feature for the workflow in which I'm using the Subnetwork. It would be fine if it was something as simple as “Nodes inside this Subnetwork have errors”. I just need to know for sure that everything succeded; otherwise, every time I render, I have to open up the subnetwork and inspect its contents to verify this.
