I have the particle fluid wave with white caps. render the first frame it gets to a certain point and stops rendering and gives me this error. Yet if i try a different frame to render i wont get that error. Im on build 10.0.339 and am running vista 64bit. Im also getting this to see the attachment
R6025
- pure virtual function call
UT_NetPacket::read: No such file or directory
Mplay/mantra crash and error
5542 5 1- Dageris
- 95 posts
- Dageris
- 95 posts
- Dageris
- 95 posts
- Dageris
- 95 posts
Ok well hopefully haha its fixed. It seems like it could have been the point light for some reason. I will keep you guys posted
Edit- Well im almost positive now its raytrace shadows. Ive rendered it out without shadows and with depth map shadows with no errors. But when i try with raytrace shadows i get the error. Upon further investigation it seems it doesnt happen if the render is raytrace and theres raytrace shadows, it seems to happen with raytrace shadows on and micropolygon render. It also happens if i use the micropolygon physically based render with raytrace shadows on.
- drumboy354
- 28 posts
Hey Dageris, thanks for doing the self-investigation! I've JUST run into this problem.
I switched my rendering engine to Ray Tracing (instead of Micropolygon) and kept my raytraced shadows and I haven't gotten an error so far.
My renders are now 7 minutes in (of probably around 30 minutes or an hour) and it's going fine. There are definitely possibilities of this crashing later on but earlier my renders were crashing after 10 seconds.
For other people, I was getting the: R6025 - pure virtual function call error.
After getting that error I KEPT my rendering engine on Micropolygon but changed my shadows to Depth Map. However, I then got Error Code: -1072…. (whatever the rest of the numbers are).
So it seems switching my rendering engine to Ray Tracing fixed it. Although, I'm hoping that the renders aren't dramatically different (in look) than my micropolygon renders :-x!
- edward
- 7899 posts
pure virtual function calls are usually bugs. Please submit them with examples to reproduce.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=15603 [sidefx.com]
