blendshapes with falloff
   3454   0   1
スタッフ
I was answering a post that went awol on blendshapes with falloff…
The Blendshapes SOP doesn't support falloff weights. It only knows how to blend between target shapes. I suspect that the question was how to pull a point on one of the inputs and have that affect a radius on the final shape.
Here's a file that shows a couple ways to do this. One on each individual input pre-deforming the input then one that applies attributes before the blendshapes then applies the deformation weights after.
Blendshapes only knows how to blend a few default attributes. I picked on Cd mapping effect strength and effect radius in to Cr and Cg respectively.
Cr = metaball weight
Cg = metaball size
You can paint in to those two attributes and put the display on the final SOP to see the effect.
blendshapes_pre_falloff.hip (115.8 KB)
