If you mac installation fails to start try this:
Go to the Administrative Tools Directory.
If you see no icons this is likely your problem.
(This installed doesn't give them correct permissions.)
Start a terminal and you must have root access enabled on you mac.
cd /Applications/Houdini 10.0.401
su root
chmod -R 777 “Administrative Tools”
chmod -R 777 “Extras”
This is making access to these tools global so set your permissions as desired if you share you computer.
My Houdini worked fine after this.
Houdini Apprentice 10.0.401 Mac failed start work around.
3745 0 0- gwoodruf
- 2 posts
