Rendering problem, need help!!
   2501   3   0
hi everyone!
i've got a rendering issue, you can see my problem in the “testrender.jpg” image, that i attached to this post (there's also a hipfile) - There is this white dotted line in between the gray areas and it shouldn't be there!
I've checked my VOP Network of the shader a thousand times, all my nodes are placed correctly, it must be some kind of bug.
it's not a problem of my mantra sampling, i already increased the pixel samples and the problem's still there.
Also i updated to the latest Houdini Apprentice Version, doesn't cut out the mistake.
My system:
Windows XP 64bit,
Houdini Apprentice 10.0.430
Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
8190 MB RAM
DirectX Version 9.0c (4.09.0000.0904)
NVIDIA Geforce GT (GS) 1024MB
(Driver Version: 6.14.11.9062 , driver date: 17.08.2009)
Now it would be great if somebody could help me, i already reported a bug but i need to get rid of this immediately
best regards,
Manuel
rendering issue.rar (121.9 KB)
http://vimeo.com/user2522760 [vimeo.com]
http://stormbornvfx.com/ [stormbornvfx.com]
Manuel Tausch
i just updated now my graphics card driver to the latest version,
problem's still there …
NVIDIA GeForce 8800 GT, driver date: 27.09.2009, version: 6.14.11.9107
:cry:
Manuel Tausch
If you use mantra, the graphics driver should not have any influence over the rendering result. As far as I know, mantra does not utilize the graphics card to speed up rendering.
Portfolio / Tech. blog: http://www.theprocedure.se [theprocedure.se]
As far as my understanding goes, i believe something goes wrong with the calculation process inside my VOP Network of the applied material.
I only updated the graphics card driver to eliminate possible errors …
Manuel Tausch
