multitexturing viewport problem
   1944   0   1
Right now I cannot get the viewport multitexturing to work correctly.
The specific problem is that the only compositing method in the v_layered surface sop that works (in the viewport) is “over”. If I change it to “multiply”, the image renders correctly. But not in the viewport.
I believe that when I looked at the example:
$HFS/houdini/help/examples/nodes/sop/layer/MultiTexture.cmd
a while ago I could change the composite method and saw a change in the viewport. But not now. I have ensured that multi-texturing is set in the viewport.
Is there some thing else I have to set?
Using Houdini 10.0.430
Thanks for any help
