Debris Rendering
   2790   0   1
Hi guys, i been playing with Debris.
i am using the default settings with the default material. but when i render i still see the particles just as tiny black dots. y change the sprite matrerial for another one that also comes with the standar materials. and same things.
is there something special that i need to set up to render sprites with debris in the render?
also how can i change the particles and use instance.
example model a rock and use that as debris.
i try to plug a copy sop after the popnetwork and copy a simple sphere just to test but nothing happen.
