I haven't looked around so this might be a known bug but I've been rendering and testing HD, and as sequences of files have ended up in different resolutions, that is frame 1 might be 1920x1080 and frame 2 might be 960x540 - I've had numerous crashes both in comp sessions and rendering.
Is there a solution, or is it that houdini dislikes mixed resolutions within sequences of files? And if it's not fixable is there a way round, as I'm doing many passes of tests both 1/2 and 1/4 as well as full and it's not always possible to get a whole sequence in one res, other than a new directory for each render and comp….
comping with differing resolutions
1946 0 1-
- harry_the_cat
- 80 posts
