Hi!
I'm asking myself very long, why we should use Multiple Solver to attach more than one solver to animation and we can't simply connect 2 or more solvers “linear way”.
So why it is required to use Multiple solver and the nattach to it RBD Solver and SOP SOlver and not simply connect RBD to SOP Solver?
From manual:
The Multiple Solver DOP causes a simulation object to be solved by more than one Solver at each timestep. Each solver attached to this node is applied in order to the object.
The effect would not be the same if we connect 2 solvers each after another?
Thank you very much
logicaly usage of multiplesolver
1657 0 2- danilo2
- 277 posts
