I need some help with shaders and shading
   Views 6129   Replies 5   Subscribers 1
I'm trying to render a glass and maybe some caustics. Can someone please tell me how to use this things in houdini (btw. they are not documented so well, except ambient occlusion) because I used the glass shader and it's cool as long as I don't render with shadows (the shadow is black no matter which shadow filter I'm using) and when I want to render from inside the glass only the reflection map is rendering (no transparency). I must admit I'm kind of lost here because I don't fully understand the way that Houdini works with ray tracing/transparencies/caustics
not sure, but i think all the photon stuff is Mental Ray specific so I wouldn't know how to do caustics without shaders, but as for your shadows, use filter shadows and be sure to set opacity to be fully opaque, Play with the Alpha instead
There's a GI with caustics video here:
http://www.vislab.usyd.edu.au/sidefx/houdini_video/by_topic/rendering/index.html [vislab.usyd.edu.au]
figures, the one rendering video i don't have
thx, for the link, caustic works fine now. But I still have the transparent shadow and glass shader BIG problem. If I use a glass shader the shadow is opaque even if I use texture shadow as a shadow shader(too bad there is no video tutorial about shadows and raytracing). Basicaly I have a glass object and inside a opaque object. Now what I expect to see in the shadow is a nice transparent shadow (a little less transparent to the edge of the glass shadow) and a opaque shadow of the opaque object. There must be a way of doing this but I'm affraid I don't know how to do it
Can someone please help me.
I've try to build a vex glass shader from scratch (like connecting facing forward or fresnel to bouth color and opacity) but it was a total fiasco.
In my opinion this capitol (rendering raytracing and some dumb vex shader creation for transparent/translucent objects like glass, water or ice) needs some more tutorials because I find myself a bit lost in the way that houdini renders
Tutorials on Shadows Rendering and optimisization.
http://www.sidefx.com/community/learn/rendering/index.html [sidefx.com]
Nate Nesler
