Question about Gasdiffuse node
   1668   0   1
Dear all:
I was working on this gasdiffuse and get a pretty good result. However, it only works with colors…
Is there any way I can also work with the shop materials? I can apply like plastic material to the fluid geometry, however, can not make the gasdiffuse works with two different materials….
Or is there any node I should use to perfectly merge two materials in the same way just like the color merging in my attached file.
Thank you for your time.^^
Cash
Finally_gasdif.hipnc (582.7 KB)
