Is pyro shader res-dependent?
   1870   0   0
Hi,guys,
I wonder whether the pyro shader is res-dependent.The problem is the rendering the result is varying between my low-res test(320*240) and high-res final(1024*720).with the final one,I just regenerate the scattering PCs and leave all the other parameters the same as the low-res one.
The result is below
