Houdini 10.0.595 (free version, Mac OS) Help section display
   4435   5   1
I am using Houdini 10.0.595 on my Mac.
When I go to the help pages, and compare them with what is shown for Houdini 9.1 in the “HOUDINI The great escape Vol.1” series, I do not get the same thing as what he shows..
I also note that it gives an error at the bottom of most web pages..
Is this something I need to fix - if so, what do I do please?
Thank you.
Additionally - I found a tutorial you offer on how to use the Help system in Houdini 9, and I do not see the help button in the upper right hand corner of the window, as is shown in the screenshot below - how do I get the help panel to work in Houdini 10?
And - in a related question..
I am on a Mac.
When in Houdini 10 - pressing the F1 thru F19 function keys does not work.
I get the default Mac shortcut assignments for those keys instead.
Is there a way to get these F-keys to work in Houdini please?
For example - the F1 key is supposed to bring up context sensitive help in Houdini, but the F1 key instead wants to lower the brightness of the Mac display.
Thanks again.
hold your function “fn” key on your mac keyboard and then F1 or others
roughsporty
I am not on a laptop, and do not have a “fn” option.
The modifier keys I have are: “control”, “option/alt”, and “command”.
スタッフ
The embedded browser was an option on other platforms in past versions but a floating browser was used on the Mac.
The start here help has changed in H11 - it doesn't come up automatically - you need to select Help > Start here.
Here is another printable Quick Reference guide which was designed for H9 but still works for H11:
http://www.sidefx.com/images/stories/blogs/houdini9_blog/h9_quick_ref_card.pdf [sidefx.com]
Robert
