I created volume data import SOP node with HDK. (windows 7 64bit, MSVC2005).
this SOP_Node is volume raw data file import node
OP_ERROR SOP_GETCELLDATA::cookMySop(OP_Context &context)
float now = context.myTime;
gdp->clearAndDestroy();
volumeGdp = (GU_PrimVolume *)GU_PrimVolume::build(gdp);
volumeGdp->setTransform4(xform3);
voxelHandle = volumeGdp->getVoxelWriteHandle();
voxelHandle->size(global_grid.grid_x, global_grid.grid_y, global_grid.grid_z);
for(int i=0; i < localGrid.local_x; ++i) {
for(int j=0; j < localGrid.local_y; ++j) {
for(int k=0; k < localGrid.local_z; ++k) {
localIndex = (i * localGrid.local_y + j) * localGrid.local_z + k;
voxelHandle->setValue(i + localOffset.offset_x, j + localOffset.offset_y, k + localOffset.offset_z, (float)(internalBuffer * intensity + offset));
gdp->notifyCache(GU_CACHE_ALL);
return error();
this code makes volume primitive very well. but when current frame was moved.
H11 crash this line.
gdp->clearAndDestory() //
without gdp->clearAndDestory() code
when frame moved i get new other volume primitive.
this code (gdp->clearAndDestory()) is works very well except volume primitive.
How can I solve this problem.?
