DOPs -- initial state, cannot add objects to SIM afterwards
   2185   0   0
I've got a basic FLIP fluid setup that I'd like to compute a “runup” for, which I would then use as an initial state. Is it possible to start a sim using the dopnet's “initial state” parameter and then add RBD objects to the simulation later in the simulation (some time after the start frame?). I'm having trouble getting this to work. I've attached a basic example (not including the runup .sim file)
Thanks for any help you can provide!
-JS-
dops_adding_to_initial_state.hip (310.9 KB)
