Compositing many layers problem
   1410   0   1
H 11.0.547 / Linux / .pic files
Seems like something that should be trivial, but I can't get to work.
I have many sequences I'm trying to layer together… for example…
A.0001.pic - A.0100.pic
B.0075.pic - B.0200.pic
C.0175.pic - C.0300.pic
and so on…
All I'm trying to do is comp A over B over C… etc.
Comp always stops and complains it's missing frames outside of the range of the various sequences.
Have tried the layer cop, and even a series of over cops… same problem.
Have tried all options for “Missing Frames” options and turning off “Warnings”.
It works if I place an empty frame at the beginning and end of the full range for each sequence, but then I end up with dozens (in this case) of frames being called for each step… instead of only two that might be overlapping.
I must be missing something simple.
Thanks.
Floyd Gillis
