Hello, i have a problem with saving to network
windows2003 AS 64bits. path is:
Frequently i receive error while autobak and regular saving process.
Error log:
Save failed for //Fs/projects/houdini/projects/020-prj/020-scene_50.hipnc
Error: Saving to stream failed (ref: String Save <Invalid argument>).
Error: Saving to stream failed (ref: Save Command String <Invalid argument>).
Error: Saving to stream failed (ref: CPIO Packet Close Write <Invalid argument> .application).
It appears very often.
I have very good 1gbps network and connections to server is very good. Problem appears only with network path to HIP file. Maybe i should use mapped network drive for using houdini?
Houdini version 11.0.553
thanks
HIP file in network storage under windows. Saving errors
3058 0 0- evgen
- 63 posts
