I would like to constrain a RBD object to one of the wires in the attached simulation. I have tried using several different kinds of constraints but nothing really does what I want. I simply want to add an object to the end of one of the wires that will act as a weight and affect the movement of the wire.
Also, is there a way to attach the constraints to a point on a piece of geometry rather than an arbitrary point in space? Really enjoy working with wires in Houdini but need a bit of help to take things to the next level.
Thanks in advance for any tips or advice.
Adam
manipulating constraints in a wire simulation
2980 1 2- gaileyag
- 14 posts
- ben4096
- 16 posts
You should read this thread, I think it's pretty close to want you looking for :
http://forums.odforce.net/index.php?/topic/12539-up-like-balloons-setup/page__hl__balloon__fromsearch__1 [forums.odforce.net]
To contraint a wire to a point on a geometry see the (very simple) attached file.
ben
ben
