Shatter with metaballs magnet fields
   3161   0   0
Is there a way to keep the shattering with metaball/magnet in the
DOPs automatic voroni fracturing system from “exploding” on a per metaball or per magnet field basis.
It seems that If I place a magnet field with a metaball inside of an RBD object, it wants to radially explode. out from the center of that metaball.
The metaballs are scaling up on a single frame to cover over areas I want to shatter. I'm not sure if its this scale anim or the nature of the voroni fracture system thats making them explode outward, but the only way I can dial it down is on the voroni fracture configure node itself, and that seems to be kinda clunky if I also want to use it to collide pieces with the floor later on in the sim.
can anyone enlighten me as to how the system is actually wired up internally, I can't seem to find the nodes that its sourcing the velocity for metaball / magnet “collisions” from ?
thanks in advance
-johnc
