Anyone using version 11 with Torque 3D
   2329   1   0
Just wondering if anyone has confirmed that the Torque 3D export still works with Apprentice HD version 11. I've only seen posts from people up through version 10 so I'm just double checking.
I know it SHOULD work, but I've been burned by competing products and there appears to be no way to test the export without first purchasing so…
Anyone?
OK, never mind.
I took the plunge and bought an HD license. I was able to export an animated model directly to Torque 3D quite easily.
I saved it directly into the Torque art directory tree and then was able to load it into the model editor and play the animation.
I can now pop back and forth between Houdini, tweak the model, render it to Torque and reload it into the world editor with the changes.
Awesome! This is exactly what I needed.
