Help with displacement shader
   3542   0   0
Hi all,
I'm trying to make a displacement shader to implement into a snow shader.
But it's not working the way I intended.
The shader I'm trying to make is here:
snow shader [creativecrash.com]
Below is the pattern I want to use as displacement.
Trying to apply the displacement into here.
Results:
Things that I've tried:
converting the pattern into HSV
converting the pattern into luminance
Using the fit node to decrease the displacement amount
Using the normalized node but it seems like displacement will not work after…
Someone please advise, thank you for your time.
No idea why the images doesn't work.
Visit the link below to see screen shots.
for the file please visit:
http://forums.odforce.net/index.php?/topic/13106-help-with-displacement-shader/ [forums.odforce.net]
