mantra surface shader error messages
   2677   0   1
h11.701 on linux
Am still not too familiar with the “mantra surface” shader and getting some errors when rendering. Hoping someone might be able to point me in the right direction.
When I assign a default mantra surface shader to geometry it renders (PBR or MP) with no errors.
Once I begin editing parameters in the tabs I start getting render error messages. Here's a sample…
mantra: VEX warning: Unknown parameter: ‘vm_truedisplace’ Undefined symbol
mantra: VEX warning: Unknown parameter: ‘0’ Undefined symbol
The more parameters I edit the more error messages I get… ‘noiseAmp’, ‘baseColor’, ‘refl_objs’, ‘refl_sep’, etc, etc.
Anyone else see this? Could this be an install or PATH issue?
Edit: Received a reply from SESI support regarding this…
We've heard this complaint from other clients, I am adding you to bug# 43616
It seems somewhat related to using displacement shaders and surface shaders in the same network (as the mantra surface does).
In any case, the warnings are harmless…
Floyd Gillis
