Using compiled vex shaders in ifd file
   2781   0   0
I have written some shaders as text and saved them in vfl files. Then I compile them into a otl files called shaders.otl.
Now I want to use these shaders in a mantra ifd file for rendering, but I'm unsure how to use them. I added a path to the otl in the ifd file:
ray_loadotl cmantra/project/shaders/shaders.otl
Then later in the ifd file, I try to use the shader like this:
ray_start object
ray_transform 17.980289 0 0 0 0 17.980289 0 0 0 0 17.980289 0 0 0 0 1
ray_geometry /meshes/plane
ray_property object surface simpleLambert_surface
ray_property object name “plane”
ray_end
Of course this does not work, I get an error:
mantra: VEX error: Unable to open simpleLambert_surface.vex Path not found
mantra: VEX error: Unable to load simpleLambert_surface Path not found
I think I'm not familiar enough with the correct implementation of shaders and surfaces in houdini, so any hint how I can make my shader work or whre I can find more information would be appreciated.
I was able to import my otl into mantra as new library. There I can create a new shop/surface node and there it appears in “digtal assets”. If I then create a shop node, I can assign and render from within houdini and the result looks promising. But I'd like to avoid this procedure if possible and use the shader directly in the ifd file.
renderwiki.com openmaya.net
