Can I determine whaat parameter is calling a menu script?
   5791   8   0
Is there a way to determine what the calling parm is when a menu script is run?
The usual kwargs data does not appear to be availiable, which can be problematic in a multiparm situation. It seems the best I can do is to run some kind of post/validation job as an additional parm callback (ugh).
If this is currently impossible, then this would be a useful RFE.
kwargs and it's corresponding ‘parm’ information seems to work fine for me in Python menu scripts regardless of them being in a multiparm or not. Can you provide an example where you are having issues?
Please check /out/This.
There is one user parm with a menu script.
I would like to access kwargs-type data.
example.hip (48.5 KB)
you have accessed it
you just need to return pairs of value, label
like this
t = kwargs
l = kwargs
return
FX Supervisor
Method Studios, NY
I get an error trying to do tamte's example.
File “<stdin>”, line 2, in expression
NameError: global name ‘kwargs’ is not defined
weird, because your scene worked for me, just the menu was populated with wrong values, but kwargs was recognized
FX Supervisor
Method Studios, NY
I am running 11.0.469 on Linux. Is this a bug with this version? Can anyone else verify that this works (or doesn't…)?
Friday, August 27, 2010
Houdini 11.0.486: Passing a kwargs variable into Python menu scripts to let you know which parameter contains the menu.
Thank you.
