Possible to scope all channels of a scene?
   4840   3   2
It seems a easy thing to do, but I can't find a way to do it.
I want to scale all the keys in my scene so that I can extend the duration of my animation, the problem is, there is quite a lot of keys which are distributed in all level of the scene, including shop node, what is the best way to go? I want to scope all the channel animation in the timeline for scaling, is it possible?
Thanks in advanced
a ‘naivo-diabolic’ solution wd be this ;
> reduce the frame range of your scene from start to the end ( the last / biggest actual frame of animation )
Warning !!! Do not ‘alter channels to fit the new frame range’ !!
> now do the opposite .. ; redefine ‘the End’ ( the last frame of the scene ) ,
but .. ‘alter channels to fit …… ’ !
good :twisted: luck !
except the things that cannot be seen , nothing is like it seems .
How about
chscope */*/*/*/*
You may need more stars. If you view this in a dopesheet, I think you can then grab all the channels and do your thing. Failing that, simply grabbing all the keys in the channel editor will work too.
Sean Lewkiw
Machine FX - Cinesite MTL
or
in a textport
-> cd /obj
/obj -> chscope * */* */*/* */*/*/* */*/*/*/*
Robert Kelly
