attributes enquiry
   2152   1   2
I'm running Radiance (which is a lighting simulation software) in Houdini. I have gotten the results (see Image 1). Under the Points view, there is the column “illuminance” which stores all my results. What I want to do is to use the average of all the illuminance divide by the minimum value.
I have tried to do it with attributepromote node to get average value (image 2) and the minimum value (image 3) separately. But I don't know how to move on and to create what node to do that division.
I hope someone can help me here, thank you!
images.zip (1.0 MB)
have an attribcreate node and set it to detail-float. go to the value tab and hv the code written for the division of the two parameters.
Cheers
ViSiKa
