pCaptPath access problem
   2824   4   0
Good day))
I'm working now under python script to export rigged mesh to some binary format. And I met some little problem here.
I need to now what region and what weight has point. This I can found in pointAttribute - pCapt. But instead of path to bone SOP I get only index of this region.
I've read that this SOPs path I can find in pCaptPath list. But it is always empty. And doesnot contain any paths))…. So can someone tell me what I'm doing wrong and what I need to do to read this data.
Thank you.
Have you tried using hou.Geometry.stringListAttribValue(“pCaptPath”)?
Thank you for your answer)
But yes)) I did it. And unfortunately I always receive empty list. By the way I can't see any info in pCapthPath column in Details tab.
>>> geo
<hou.Geometry in /obj/tube_object1/tube_object1_capture1>
>>> geo.stringListAttribValue(“pCaptPath”)
Oops, sorry … Here you go:
>>> attrib = hou.node('/obj/torus_object1/torus_object1_capture1').geometry().findGlobalAttrib(“pCaptPath”)
>>> attrib.strings()
('chain_bone3/cregion 0', ‘chain_bone2/cregion 0’, ‘chain_bone1/cregion 0’)
Oo!!
Great! It works!))
Thank you for your help.
