how to properly set up tear- and dentable cloth ?
   2196   0   0
I recently started playing around in dops after watching the crumpling and tearing masterclass.
Well I already managed to set up tear- and dentable cloth - however i now got stuck with setting up proper cloth parameters. I actually wanted to created a metal like material, but i never get the cloth to plastically deform correctly. It's either jumping back into its original position after tearing (probably due to high stiffness values ) or it's to weak to maintain it's shape :? (simple tube) .
I'll attach the file - it would be great if someone could have a look at it – an maybe tell me what the “magic numbers” are.
By the way: is there any special technique or workflow for recreating dynamic materials in dops? or it it really just playing around with numbers until you get the behaviour you want ? It also would be helpful to know how you have to change these properties if your are changing the density of your geometry.
thanks in advance
cloth.hipnc (269.1 KB)
